It is currently Thu May 28, 2026 10:35 am
PostPosted: Fri Oct 19, 2007 11:06 am
Does anyone know if a late A body front bench seat has the same bolt pattern as an early A body.
Trying to find a cheap seat for my 66 Valiant.
thanks!
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri Oct 19, 2007 11:15 am
I run a split bench with the buddy seat that has six way power in my '64 and I love it. I'm not sure of the vintage but I would guess late 70s Dart or Duster. I had to replace all my floors so I was starting from scratch anyways but I'm almost positive you will have to drill some holes in your floor to make it work. Definitely a good upgrade if you're not a stickler for period correctness.
 Post subject: yup!
PostPosted: Fri Oct 19, 2007 4:17 pm
I have installed several late A-Body bench seats into 60-66 A-bodies with very little work. I find that it is best to re-use the seat tracks from the old (original) seat. These have pressed in studs that allow them to be bolted to the seat. Later seats have similar bolts, but in the seat frame itself. I simply press out the ones in the seat tracks and bolt them to the new seat using the later system. (The spacing is identical.) Works like a dream! Let me know if you have other Qs.
. . . there was good sport at his making.
