Cheap, easy upper radiator hose trap.
https://slantsix.org/forum/viewtopic.php?t=25282
Page 1 of 1
Author:  Old6rodder [ Tue Oct 09, 2007 3:09 pm ]
Post subject:  Cheap, easy upper radiator hose trap.
I've been asked to put up something about my way of doing a screen trap for the radiator. I've thought it was pretty much self-evident but I made up a photo and description album in Flickr for a friend, so here 'tis if you need it ..............
Radiator trap
Author:  slafolle [ Tue Oct 09, 2007 4:55 pm ]
Neat idea, and simple, thanks for sharing! I wouldn't have thought debris that size could get past the themostat.
Steve
Author:  thomasj6604 [ Mon Oct 15, 2007 9:33 pm ]
Hi, Ilooked at the slide show of the trap. Is it made of wire window screen? How do you wrap it to make the "plug"?
Author:  thomasj6604 [ Fri Oct 19, 2007 6:21 pm ]
I did this now. I think it will work great. THANKS!!
Author:  Old6rodder [ Fri Oct 19, 2007 11:32 pm ]
Howdy,
I apologize for not getting back to you sooner on your questions. This is rather a busy time of year for me, 60+ hour weeks 'til mid-January.
Yes, it's window screen. The wire sort (not the plastic) and galvanized if possible. Just roll a flat sheet into a cone by overlapping it from the center point of a circle out along a radian. Makes one side three layers thick but doesn't allow any "leaks". The screen can be worked a bit into sort of a condom shape. Actually rather appropriate at that ....
I make it long enough to rest inside the tank, clear of the upper tube, in order to allow for plenty of working surface area.
