| Vac. canister https://slantsix.org/forum/viewtopic.php?t=2530 |
| Author: | Mike P [ Thu Aug 09, 2001 11:03 am ] |
| Post subject: | Vac. canister |
Are the Vac canisters on 67's distributor's adjustable? I couldn't get the 3/32" allen in mine, so I drilled it out, then I couldn't find allen hole in spring backer plate. The advance comes on at 15" vac and full at 22". OK? Can I upgrade to a V8 canister? Thanks |
| Author: | Doctor Dodge (Doug Dutra) [ Thu Aug 09, 2001 9:26 pm ] |
| Post subject: | Re: Vac. Advance canister |
: Are the Vac canisters on 67's distributor's : adjustable? I couldn't get the 3/32" : allen in mine, so I drilled it out, then I : couldn't find allen hole in spring backer : plate. The advance comes on at 15" vac : and full at 22". OK? Can I upgrade to a : V8 canister? Not all of the vac. pods are adjustable and the big block V8 ones are different. (LA engines one works) The adjustable ones can be ordered through Crane Cams, for the points Dist. it is p/n 99605-1 Electronic dist. use p/n 99604-1 These are good kits and come with advance springs, instructions and the allen wrench. DD |
| Author: | Mike P [ Fri Aug 10, 2001 8:29 am ] |
| Post subject: | Tks again Doc. *NM* |
