| block o -ring https://slantsix.org/forum/viewtopic.php?t=25339 |
| Author: | terrylittlejohn [ Fri Oct 12, 2007 12:43 pm ] |
| Post subject: | block o -ring |
does any one have any exsperience o- ring a block, i need to know what size and type of wire, what distance the groove has to be from bore and the dimension of the groove, width and depth. a local machine shop can do it but i need this information for them. |
| Author: | Joshie225 [ Fri Oct 12, 2007 12:48 pm ] |
You can also do the job yourself with the Isky tool. http://www.iskycams.com/pdfcatalog/2004-05/page16.pdf |
| Author: | terrylittlejohn [ Fri Oct 12, 2007 1:12 pm ] |
yes that might be cheaper than the machine shop |
| Author: | Dart270 [ Fri Oct 12, 2007 2:06 pm ] |
Several of the racers have done this. I think the Drakes, Hambys, Cameron Tilley, Coxes, etc have done it on NA, boost, and N2O motors. Cameron Tilley has o-rings on his turbo motor (up to 22lbs boost and 720HP) - just the block, IIRC. Tilley has put o-rings on that just hit the fire ring on a nice Aussie composite gasket, which he says works well over 12:1 comp. I think his turbo motor has the copper gasket, though. Lou |
| Author: | terrylittlejohn [ Fri Oct 12, 2007 2:32 pm ] |
i am not familiar with the auzie comp gasket but would o-ring and fle-pro comp gasket work together? |
| Author: | Charrlie_S [ Fri Oct 12, 2007 5:18 pm ] |
I had my 170 turbo block is "O"-ringed. But that was about 20 years ago. A race machine shop did the work, and I don't remember the specs. I do remember the wire is stainless steel. It has never been replaced. I am now using the Cox Bros copper gasket. |
| Author: | terrylittlejohn [ Fri Oct 12, 2007 5:24 pm ] |
charlie i was told that it takes 3 to6 hrs to set up and cut 6 grooves in a milling machine does that sound about right to you, if it is buying to tool myself would problably be cheaper,no local shop has a 0-ring tool. |
| Author: | Charrlie_S [ Fri Oct 12, 2007 8:42 pm ] |
That time does not seem unreasonable to me. If you are only going to do one block, it might be better to rent the Isky "groove-o-matic" for $60. I did not see a Purchase price listed on that page. |
| Author: | ceej [ Fri Oct 12, 2007 11:17 pm ] |
$590 Retail, only $295! I suppose $300 Bucks isn't bad. http://www.iskycams.com/partnum_templat ... 16&go.y=11 CJ |
