It is currently Fri Nov 27, 2026 11:40 am
 Post subject: Measuring Journals
PostPosted: Mon Dec 17, 2012 9:31 am
Okay so I found out today my micrometer does not have precision to .0001 so I know I can not use it to get an accurate reading but I did take a rough reading.
The service manual says:
Main Bearing Journal Diameter: 2.7495 to 2.7505
I read from front of block back:
1: 2.760
2: 2.746
3: 2.751
4: 2.749
I think I may not have closed the micrometer enough on number 1 and maybe 3 also I am not sure if the micrometer is rounding. I am looking for a .0001 micrometer but based on what is seen here should I expect to have the crankshaft worked?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon Dec 17, 2012 9:37 am
Car Model: 64 Valiant
The #2 journal, based on the specs you measured, is well under the low side tolerance for standard. You also didn't mention if the journals were round or out-of-round by any amount. Its more than likely going to need to be reground based on what the #2 journal measures. What condition are the rod journals in as far as what you have mic'd.
PostPosted: Mon Dec 17, 2012 9:46 am
Car Model: 1964 Valiant V200
You also need to measure at a couple of different points because journals wear oval.
If you are unsure, just bring it to your machine shop, usually they will check it for you for a few $$, sometimes even free if you are paying them to do other work.
PostPosted: Mon Dec 17, 2012 10:50 am
I did not measure the rod journals yet. I also did not measure in a couple of places although I did pull my mic back and forth across the surface to try and make sure I got a good reading.
I think I am going to bring it to my machine shop anyway. I want this to be a nice engine and like I said in my previous post I want to be able to pop off the line if I should choose to. I also recently picked up another head that I am going to have him work for me.
I am looking for 9.5 to 10 compression ratio. I am also considering some port matching and maybe polishing. If the cost does not skyrocket.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
