| Tachometer? https://slantsix.org/forum/viewtopic.php?t=25357 |
| Author: | thomasj6604 [ Sat Oct 13, 2007 8:59 pm ] |
| Post subject: | Tachometer? |
I was given a Sun Super Tach. II. Previous owner said it did not work on his fuel injected 305 ChevyV-8.Is it possible this tach. would function on a six cyl., but not on a v-8? Also, could I use the nice factory tach. out of my 1992 Caravan(with the crappy Bendix Antilock brakes.) As I've posted before, my vehicle is a 1979 stock 225 1bbl.2wd, D-100 pickup. (This year truck could have been ordered with a factory tach. as it came standard on the Warlock and Lil Red Express.) All opinions on gauges for slants, but especially tachometers are appreciated. THANKS. |
| Author: | Rob64GT [ Sun Oct 14, 2007 4:24 am ] |
Your Sun Super Tach II will work fine on your slant six. There is a switch in the back for 8,6,4 cyl operation. I am not sure why it wouldn't work on your friends V8. As long as your have a distributor it will work. Hear is a link to the manual http://www.sunpro.com/publish/2007/09/2 ... _16472.pdf |
| Author: | thomasj6604 [ Tue Oct 16, 2007 7:20 pm ] |
I looked at the switch on the back and it was set on 4 cylinders,so I set it on 6. No wonder it didn't work on his V-8! The motto is; Don't forget to "switch" your switch !! |
| Author: | sethmcneil [ Tue Oct 16, 2007 10:22 pm ] |
I've always liked "When all else fails, follow the directions!" |
