| Oil Pump cover gasket https://slantsix.org/forum/viewtopic.php?t=25367 |
| Author: | ceej [ Sun Oct 14, 2007 12:36 pm ] |
| Post subject: | Oil Pump cover gasket |
My favorite parts house only lists the pump to block gasket. How about a source/PN for the gasket for the pump plate? Just make one? CJ |
| Author: | Joshie225 [ Sun Oct 14, 2007 1:00 pm ] |
CJ, The pump cover should have an o-ring. Joshua |
| Author: | ceej [ Sun Oct 14, 2007 1:09 pm ] |
Ah. Where do I get one? Locally. Paying $6 shipping for a 74 cent part is a bit silly. CJ |
| Author: | SlantSixDan [ Sun Oct 14, 2007 1:12 pm ] |
An industrial supply place that stocks O-rings ought to be able to supply you with a Viton O-ring that'll get the job done. Buna-N would be a second-preference material. You can bring along the pump for sizing (pick the one that fits in the groove and stands a little proud of the surface so the cover will compress it and form a seal). |
| Author: | ceej [ Sun Oct 14, 2007 1:17 pm ] |
I've got the pump back in the car, so taking it in would be a pain. Anybody know the size of the O'ring? CJ |
| Author: | SlantSixDan [ Sun Oct 14, 2007 1:32 pm ] |
I was hoping an FPC would give dimensions, but all it tells me is that the p/n is 2268 921. Doc? |
| Author: | Charrlie_S [ Sun Oct 14, 2007 3:44 pm ] |
I have a couple of extra's. They come in the Fel-Pro engine gasket set, and I don't use them. If my pump is old enough to warrent the cover gasket, I just replace the pump. PM me your mailing info, and I will send you one. Deception Pass Motor Parts Anacortes, Wa, 96221 360-299-2582 Collectors Auto Supply Oroville, Wa. 800-414-4462 Tonkin Parts Center Portland, Or 800-546-6900 All list the part number 2268-921 in stock. I have found Collectors to be pricey. |
| Author: | Pierre [ Sun Oct 14, 2007 9:25 pm ] |
I've bought them in the past from napa. Think it was in Victor-Rsomething.. Reinz? brand |
| Author: | ROADRUNNER7169 [ Mon Oct 15, 2007 6:01 am ] |
you can get one at the dealer part # 2268921 and it lists for $1.00 they might have to order it but it should only take a day or 2 to get |
| Author: | Charrlie_S [ Mon Oct 15, 2007 1:03 pm ] |
Cover "O"-ring on the way. Snail mail. |
| Author: | ceej [ Mon Oct 15, 2007 1:13 pm ] |
Thanks Charlie! What do you want for Christmas? CJ |
| Author: | Charrlie_S [ Mon Oct 15, 2007 2:30 pm ] |
Quote: What do you want for Christmas? CJ |
| Author: | ceej [ Mon Oct 15, 2007 3:04 pm ] |
OK. Who do you want to kick? Thank you! CJ |
