It is currently Thu Nov 26, 2026 5:29 pm
PostPosted: Tue Oct 23, 2007 6:42 am
Hi
I have to replace the axle seals on a 1965 Valiant. I think that the differential is called the 7 1/4 inch since it has 9 inch drums. The original seals are some "natural fiber" I would like to replace those crappy things with neoprene seals. Does anyone know where I could get such a thing?
Thanks
PostPosted: Tue Oct 23, 2007 11:22 am
Contributor
NAPA had them two years ago when I replaced mine. There was some confusion with the NAPA part number application at that time, so make sure they are clear on the model.
PostPosted: Tue Oct 23, 2007 7:48 pm
I got the seals.
Did you put a bit of gear oil on the seal or did you install them dry?
PostPosted: Wed Oct 24, 2007 4:46 am
Contributor
In this case, I gave them to the mechanic who replaced the axle bearings and did some other work.
I don't know if it's required, but I always apply some lube to neoprene seals when I install them myself. It just seems logical to not have dry surfaces rubbing against each other.
