It is currently Tue Jun 16, 2026 4:54 am
PostPosted: Fri Oct 19, 2007 8:33 am
Hey All,
I noticed that the carb base gasket in my fel pro kit dosen't have a cutout for the pcv passage. I'll just cut it out with a punch. But then I noticed that there are other ports on the base of the BBS carb. Are these supposed to be sealed by the gasket?
I'm sure this carb will need a rebuild too. Are there many different rebuild kits for the BBS? I don't see any numbers on it to reference. Am I missing something. Does anyone know the rebuild kit part # I would need? Or do I need more info first.
Thank you!
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri Oct 19, 2007 11:37 am
Whether or not there are different kits for different BBSs depends on whose kit you buy. I recommend a Walker kit; they're of better quality than other commonly marketed kits. There are even better/more complete/more expensive kits available from specialty vendors, but usually a good quality normal kit will do the job. The base gasket does need various cutouts, and it should be the 5/16" to 3/8" thick one, not the 1/8" thin one. I am assuming this is for the BBS you showed us a picture of a few weeks ago. In that case, the correct kit would be a Walker 15483A. If you're not sure where to buy Walker kits locally, contact Walker on 323-232-3359 or perhaps ask CarbsOnly if they can supply it.
Users browsing this forum: Ahrefs [Bot] and 1 guest
