| /6 Performance https://slantsix.org/forum/viewtopic.php?t=25452 |
| Author: | 68barracuda [ Sat Oct 20, 2007 3:24 am ] |
| Post subject: | /6 Performance |
WEEEEEEE Did 3 X 2 way 1/4 runs this morning 92mph average!!!! with timing gun - got a buddy who is a traffic cop. Conditions - overcast, no wind 23 celsius, 4970 feet above sealevel Any ways this slant is more fun than a barrel of monkeys. Switched over to a MSD Balster 3 coil ( no 2's in stock), Accel 8 mm wires , and accel rotor, gave it 11 degrees advance and what a pleasure TIP : DO NOT use Pertronix wires they are absolute rubish At first i thought i did something wrong - looked like a light show in the dark with all the arcing goin on, and a terrible idle, so got a second set, with the same result - this was with a pertronix coil, tried a generic coil, same result, tried other pertronix wires with both coils, same result, swapped rotor's, still the same............... Got rid of the pertronix wires and all is ok , fitted the blaster 3 and life is a song - and that song is a slant going full bore |
| Author: | terrylittlejohn [ Sat Oct 20, 2007 6:11 am ] |
| Post subject: | /6 performance |
usually if i am on that end off a radar gun it a ticket |
| Author: | 68barracuda [ Sat Oct 20, 2007 3:25 pm ] |
car 68 barracuda 2910 pounds ex driver (200 std rearend 2.92 Ithink Engine HEI driving a MSD Blaster coil accell wires and rotor arm plugs gapped at 0.045 9.5 cr, std valves but 5 angle valve job, valves unshrouded, some blending valves backcut Holley 4150 vac sec 450 cfm on chrysler South Africa 4bbl manifold a lot like the clifford Inlet and exhaust manifolds extrusion honed, and port matched 2 1/2 inch stainless exhaust with free flow muffler Torqueflite 904 Flexa lite flexfan - for what it is worth ....just noisy and a heavy right foot, manually up shifting at 4000rpm |
| Author: | terrylittlejohn [ Sun Oct 21, 2007 8:18 am ] |
| Post subject: | /6performance |
that`s a pretty good 1/4 mph time with 2.90 gears, is there a big difference in the africian intake |
| Author: | slantzilla [ Sun Oct 21, 2007 8:21 am ] |
Sounds like a pretty good running car ya got there. |
| Author: | 68barracuda [ Sun Oct 21, 2007 10:52 am ] |
| Post subject: | Re: /6performance |
Quote: that`s a pretty good 1/4 mph time with 2.90 gears, is there a big difference in the africian intake
looks a lot like the clifford 4bbl as far as layout is concerned - bigish plennum etc - but was meant for a carter afb with small boltpatern - used ~ 77 to 81 as factory standard - so I do have an adapter on it wich with a lot of patience I have nicley matched to the manifold and carb - dont you just love engineers blue and a dremmel?I agree - she is a bit slow - relatively speaking - of the mark but once she get moving she just winds up - the induction roar once the secondaries opens up is music I have a 3.23? rearend waiting to be installed- it has 10 inch drums, and the bigger boltpatern 4 1/2 inch it will go in as soon as I have my front 11 inch disc upgrade ready one advantage of the Australian rearend is that it moves the wheels outward by about 2 inches a side - more space for wider wheels, as well as getting rid of the 68 barracuda tippy toe stance in the rear With the car performing like this I am starting to experience major fades and funky smells if I do not allow for cooling down - the 9 inch drums must go The 2.90 gears are starting to complain about all the testing........ |
| Author: | terrylittlejohn [ Sun Oct 21, 2007 12:26 pm ] |
yes those 3.23 will get you up and moving compared to 2.90`s,is the rear 81/4 or 83/4, i know the 81/4`s here are only 49in backing plate to backing plate |
