| Gas vs Alcohol https://slantsix.org/forum/viewtopic.php?t=25460 |
| Author: | 66aCUDA [ Sun Oct 21, 2007 7:08 am ] |
| Post subject: | Gas vs Alcohol |
Have both available to race with or even a blend. Questions are: 1 whats the diference in preformance (ETs) 2 are there any considerations in the engine build? This is Drag only Still considering a power adder car. Thanks Frank |
| Author: | slantzilla [ Sun Oct 21, 2007 8:27 am ] |
Alcohol motor will be able to use more compression than a pump gas motor. I have seen guys switch back and forth between race gas and methanol. Meth will make a ton more torque and will change less when the weather changes. There is currently a lot of interest in E-85 because of the octane rating and cost. Main drawback I have seen so far is quality has been very spotty. One thing to remember if you want to try and spray with alcohol. Your tune-up has to be spot on or you will hydraulic a cylinder and push the crank out. Turbo works well with alcohol, but again, tune-up is crucial. |
| Author: | 66aCUDA [ Sun Oct 21, 2007 12:07 pm ] |
Thanks Dennis So there isnt any special gaskets or what not between the two? I remember back in the mid 80s I couldnt run gasahol in my Toy truck (injector o rings or something) also bad proformance. Would you sugest starting with a blend and work my way up? You say Spray? like NO2? I thought It was used to replace the gas. Thanks Frank |
| Author: | Charrlie_S [ Sun Oct 21, 2007 2:04 pm ] |
Nitrous (NOS) is used to augment the air, not replace gasoline. Nitrous is an oxidizer, and brings more oxygen to the combustion chamber. It is necessary to add additional fuel ( gasoline, alcohol, etc), when the nitrous is turned on. |
| Author: | slantzilla [ Sun Oct 21, 2007 2:32 pm ] |
Frank, I would either run gas or alcohol, never a mixture of both. E-85 is the exception, but I'm guessing that's why there are fuel quality issues. Hard to get the mix right. |
| Author: | 66aCUDA [ Sun Oct 21, 2007 5:49 pm ] |
Thanks Guys That makes good sense. Its nice to know that the motor will work with a power adder. Frank |
