neoprene axle seals for 1965 valiant?
https://slantsix.org/forum/viewtopic.php?t=25489
Author:  saskatchewan [ Tue Oct 23, 2007 6:42 am ]
Post subject:  neoprene axle seals for 1965 valiant?
Hi
I have to replace the axle seals on a 1965 Valiant. I think that the differential is called the 7 1/4 inch since it has 9 inch drums. The original seals are some "natural fiber" I would like to replace those crappy things with neoprene seals. Does anyone know where I could get such a thing?
Thanks
Author:  64 Convert [ Tue Oct 23, 2007 11:22 am ]
NAPA had them two years ago when I replaced mine. There was some confusion with the NAPA part number application at that time, so make sure they are clear on the model.
Author:  saskatchewan [ Tue Oct 23, 2007 7:48 pm ]
I got the seals.
Did you put a bit of gear oil on the seal or did you install them dry?
Author:  64 Convert [ Wed Oct 24, 2007 4:46 am ]
In this case, I gave them to the mechanic who replaced the axle bearings and did some other work.
I don't know if it's required, but I always apply some lube to neoprene seals when I install them myself. It just seems logical to not have dry surfaces rubbing against each other.
