It is currently Fri May 15, 2026 3:28 am
PostPosted: Mon Oct 22, 2007 12:04 pm
What is the factory numbers for deck height and compression height for the 225 slant. I hope someone can help me I cant seem to find it. I know its not the most accurate but it will help a bunch.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
 Post subject: deck
PostPosted: Mon Oct 22, 2007 12:57 pm
almost all the stock slant`s i have stripped down were .187in down the bore :x
PostPosted: Mon Oct 22, 2007 1:25 pm
Piston 'compression height' is listed at 1.760 inches.
Piston deck height is listed at -.140
As noted, factory built engines are usually different (more) on the piston deck height number.
PostPosted: Mon Oct 22, 2007 3:59 pm
I was on the phone with crower and ross pistons to put together an idea of the cost involved with the whole custom route. The pistons were pretty reasonable at about 650+pins but the rods from crower were around 185 :shock: :oops: so that might be out of the question.
That the question they kepped on asking so heres the next one. How big/wide is the big end of the rods for a slant? bbc rod that are 6.8/2.325/.990/.991 are 110 bucks a pop. Would those be an option?
PostPosted: Mon Oct 22, 2007 9:40 pm
The SL6 con rod 'big end' is 2.187 x 1.125 wide.
PostPosted: Wed Oct 24, 2007 12:28 pm
Hey Doc what are the preferred after market rod for a hp build? I want something that will work well and be cost effective.What are you using, or anyone for that matter, for a rod thats not a stocker.
PostPosted: Wed Oct 24, 2007 1:14 pm
Im using stock rods on all my builds save one. The Duster(Gods Rods) is a pretty hot engine build and the rods are stock. Unless you are trying to set records spend you money elsewhere. My .02
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Oct 24, 2007 1:49 pm
I use stock rods in all my build-ups and have never had a con rod failure.
(Knock on wood)
I do spend a lot of time nad energy on the stock rods. I usually start with 15 to 20 rods and select the best 8, then do all the prep work.
I get to the "final 6" and those get ARP bolts, resized and balanced.
The big "tip" for avoiding con rod failure... use a real light piston.
