It is currently Sun Apr 26, 2026 5:11 am
PostPosted: Sat Oct 27, 2007 11:48 am
Anyone know a source for replacement original style spring type hose clamps and a molded upper radiator hose for a 64 Dart /6? I’ve located a molded (curved not flexed) lower hose at NAPA but still need the upper.
I've got a very original car, and I’d like to replace the hoses and clamps with the original type.
Thanks,
Scott
PostPosted: Sat Oct 27, 2007 9:26 pm
The top hose is a NAPA #777 unless they've changed numbering systems.
Spring clamps are available only through restoration-oriented specialty supply houses. If your original clamp is gone, suggest you use a screw-drive clamp until a new spring clamp can be ordered.
PostPosted: Sun Oct 28, 2007 3:25 am
restoration specialties carries several type of OEM clamps.
Juan Ignacio Caino
PostPosted: Sun Oct 28, 2007 9:47 am
Thanks much for the information. The hose will get me going, and I'll research the clamps.
Take care,
Scott
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
