| Manifold gaskets https://slantsix.org/forum/viewtopic.php?t=2550 |
| Author: | Darrin [ Mon Aug 13, 2001 7:12 pm ] |
| Post subject: | Manifold gaskets |
Which ones are the best? Do some have bigger holes for the intake/exhaust passages? THANKS! Darrin dartman225@webtv.net |
| Author: | Doc [ Tue Aug 14, 2001 12:45 pm ] |
| Post subject: | Re: Manifold gaskets |
: Which ones are the best? Do some have bigger : holes for the intake/exhaust passages? Use the gasket which matches you port size, the "stock" ones are a little bigger then the stock ports so they work in most cases. Suppliers like Clifford and Mr. Gasket offer gaskets with bigger "cut-outs" and the Cox Boys have "racer specials" for real large port jobs. The manifold gasket should never over-hang or cover the port opening in any way so tim it back if it does. DD |
