| New Super Six and Cam break-in https://slantsix.org/forum/viewtopic.php?t=25522 |
| Author: | Damraider [ Thu Oct 25, 2007 2:31 pm ] |
| Post subject: | New Super Six and Cam break-in |
I'm adding a new cam (group buy) and a Super six (from a member here) and also a set of the Dutra's . My question is, should I put the old intake and exhaust on first for cam break-in and then change the rest over ? Basically since I'm not sure on the set-up I don't want to crank and crank without starting the motor. What do you guys think ? Does Doug make house calls ?? LOL!!! Thanks, Steve |
| Author: | rock [ Thu Oct 25, 2007 3:02 pm ] |
| Post subject: | Steve,here is my experience |
Steve, Nice thing about a slant is you can't stop it from firing! Set your timing, get your wires on right plugs, make sure you have a spark, move your idle screws out 1.5 turns, use a remote start switch so you can see what is going on, and STAND BACK! You may idle rough, but you will be off the cam setting! I had two wires on the wrong plugs, no exhaust line to my dutras, looked like a fuelie with fire coming out the Dutras, but ran like .he..! Bolt it up and let er rip. your manifolds don't have a thing to do with firing. rock '64d100 |
| Author: | Damraider [ Thu Oct 25, 2007 3:41 pm ] |
Rock, OK, cool ! Thanks, Steve |
| Author: | Doctor Dodge [ Thu Oct 25, 2007 9:09 pm ] |
My biggest concern will be the carberator, is is new or "rebuilt"? The next concern is getting a good valve lash adjustment done prior to start-up. Do some "homework on that subject. My last concern, make sure the gaskets seal and there are no vacuum leaks. Cover these problem areas and the engine will fire-up and run well enough to do your "fine tuning". DD |
