Bog Down of Chrysler Slant Six 225 Engine
https://slantsix.org/forum/viewtopic.php?t=25530
Page 1 of 1
Author:  weimar63 [ Thu Oct 25, 2007 11:17 pm ]
Post subject:  Bog Down of Chrysler Slant Six 225 Engine
My question is this. Everytime I push the throttle down it wants to quit. Then I will restart the engine and pump or push the accelerator down and it takes off. It has a BBD Carb on it. I have had it rebuilt by a professional rebuilder; however it still bogs down. Need suggestions on what to look for. Thanks!
Author:  Doctor Dodge [ Fri Oct 26, 2007 6:04 am ]
Non-functioning vacuum advance. That is the vacuum pod with the small hose, on the distributor.
Stuck or slow moving mechanical advance in the distributor, where is the initial timing currently set?
As you can see, my bet is that the problem is not with the carb. but with the spark timing.
