| Original style spring type hose clamps and a molded radiator https://slantsix.org/forum/viewtopic.php?t=25542 |
| Author: | Tuff68dodge [ Sat Oct 27, 2007 11:48 am ] |
| Post subject: | Original style spring type hose clamps and a molded radiator |
Anyone know a source for replacement original style spring type hose clamps and a molded upper radiator hose for a 64 Dart /6? I’ve located a molded (curved not flexed) lower hose at NAPA but still need the upper. I've got a very original car, and I’d like to replace the hoses and clamps with the original type. Thanks, Scott |
| Author: | SlantSixDan [ Sat Oct 27, 2007 9:26 pm ] |
The top hose is a NAPA #777 unless they've changed numbering systems. Spring clamps are available only through restoration-oriented specialty supply houses. If your original clamp is gone, suggest you use a screw-drive clamp until a new spring clamp can be ordered. |
| Author: | argentina-slantsixer [ Sun Oct 28, 2007 3:25 am ] |
restoration specialties carries several type of OEM clamps. |
| Author: | Tuff68dodge [ Sun Oct 28, 2007 9:47 am ] |
Thanks much for the information. The hose will get me going, and I'll research the clamps. Take care, Scott |
