| Spark Plug Tubes... https://slantsix.org/forum/viewtopic.php?t=25546 |
| Author: | knuckledown [ Sat Oct 27, 2007 3:53 pm ] |
| Post subject: | Spark Plug Tubes... |
Had a BLAST changing the o-rings. What a fun & quick little project. Whats up Slanters? |
| Author: | Charrlie_S [ Sat Oct 27, 2007 4:13 pm ] |
| Post subject: | Re: Spark Plug Tubes... |
Quote: Whats up Slanters?
The price of gas, ....... again. |
| Author: | Rust collector [ Sat Oct 27, 2007 5:20 pm ] |
Trying to find time and money to actually do something to my slants, except getting more cores... Same old story............ |
| Author: | moparfreak77 [ Tue Oct 30, 2007 5:21 pm ] |
What holds the tubes in? just the spark plugs? |
| Author: | Doc [ Tue Oct 30, 2007 6:11 pm ] |
I always change spark plugs when I change my tube o-rings... Or is it the other way around. DD |
| Author: | SlantSixDan [ Tue Oct 30, 2007 6:13 pm ] |
Yup, just the spark plugs. |
| Author: | superman_jjs [ Wed Oct 31, 2007 3:59 pm ] |
This is something new to me. I love this site. How do you get the tubes out after you remove the plugs? |
| Author: | SlantSixDan [ Wed Oct 31, 2007 4:11 pm ] |
The spark plug tubes are only present on cylinder heads made through 1974. '75 and up heads don't have them. But if you're working with a '74 or earlier head, sometimes the tube will be "glued" in place by the cooked O-ring. In that case, usually sticking a finger into the tube and exerting sideways pressure at the inner end will break it loose so it can be withdrawn. |
| Author: | knuckledown [ Wed Oct 31, 2007 4:20 pm ] |
Mine were extremely easy to extract. I simply removed the spark plug and stuck two fingers in the tube, gave it a wiggle and it pulled right out. I had one sticky one, behind the alternator. I just used duct tape (adhesive side out) on my finger for extra grip. Worked like a charm. |
