| poor man's turbo https://slantsix.org/forum/viewtopic.php?t=25557 |
| Author: | argentina-slantsixer [ Sun Oct 28, 2007 3:39 pm ] |
| Post subject: | poor man's turbo |
Well, impatient man turbo say I wanna experience with turbo my existent motor, while I finish the car and can start another idiotic money pit and build the 4.120 stroke 91 mm bore slant, can I get away with non-forged pistons? do I have to O-ring my block? big turbo like Holset HY31 - Garret GT4088R (AR 5.0 is about the same size, BIG turbo for up to 4 liters engine and 600 hp) I just want to blow ANOTHER engine before I build the big cubes slant. |
| Author: | Matt Cramer [ Sun Oct 28, 2007 4:27 pm ] |
I'm putting a GT4082 on my internally stock slant six. We'll see how it holds up. I've heard of slant sixes running 10 psi of boost on stock internals before. |
| Author: | Shaker223 [ Sun Oct 28, 2007 4:31 pm ] |
Try 21psi. Thats what I'm running on my 100% stock slant. Watch the afr. |
| Author: | argentina-slantsixer [ Sun Oct 28, 2007 4:42 pm ] |
Quote: Try 21psi. Thats what I'm running on my 100% stock slant. Watch the afr.
I plan on running a 600 CFM holley 4160. I'll jet it "safely" shaker223, what are you using as in total timing, cam timing, ignition, etc etc? |
| Author: | Shaker223 [ Sun Oct 28, 2007 5:48 pm ] |
See here for the specs. http://www.slantsix.org/forum/viewtopic.php?t=24937 For my combo, I've found 19* of total timing to be the best. I tried 16* to 21* (verivied on a chassis dyno) and the gains from 19* to 21* were not worth it. |
| Author: | sethmcneil [ Mon Oct 29, 2007 1:52 am ] |
Quote: afr
What's that? |
| Author: | sethmcneil [ Mon Oct 29, 2007 1:58 am ] |
Air Fuel Ratio. Nevermind... |
