It is currently Tue May 12, 2026 11:05 pm
PostPosted: Tue Aug 21, 2001 2:16 pm
Just to double check....I'm upgrading my '65 170 to a 2bbrl intake. I am also going to get another exhaust manifold. Are there any clearance problems between the the combinations of 225/170 exhaust manifolds and the 2bbrl intake? What about steering clearance and such?
Orionsax7@cs.com
PostPosted: Tue Aug 21, 2001 3:34 pm
: Just to double check....I'm upgrading my '65
: 170 to a 2bbrl intake. I am also going to
: get another exhaust manifold. Are there any
: clearance problems between the the
: combinations of 225/170 exhaust manifolds
: and the 2bbrl intake? What about steering
: clearance and such?
Everything should bolt right-up.
The only thing you may have to "rework" is the length of the kick-down rod (if it's an auto trans) The shorter 170 will make the rod seem to long.
