Blown Vacuum Advance!
https://slantsix.org/forum/viewtopic.php?t=25651
Page 1 of 1
Author:  A. Lewis [ Fri Nov 02, 2007 8:26 pm ]
Post subject:  Blown Vacuum Advance!
Hey guys,
well, today I was checking to make sure i set my points right with the distributor out. So, I went ahead and checked it out to make sure it wasn't going to give me a surprise in the next few months. The gear looked fine (not much wear), o-rings good, sucked on the vacuum advance pod and got air!!! From my research in the forum--thats not good. So, my question is can I replace it without replacing the distributor or Do I have to replace the whole thing?
Thanks for your guys' help.
-Angelo
Author:  SlantSixDan [ Fri Nov 02, 2007 8:36 pm ]
Yep, you can easily replace the vacuum advance unit. Standard/BlueStreak VC-173 or NAPA Echlin VC-3011.
(Have you considered installing electronic ignition?)
Author:  A. Lewis [ Sat Nov 03, 2007 11:33 am ]
Thanks dan! Yup ! I have thought about it. I was thinking about getting the pertronix 2 setup. Thanks again!
- angelo
