It is currently Sun Nov 29, 2026 6:51 pm
PostPosted: Fri Oct 26, 2007 7:56 am
Hey Guys,
Turns out the front w/cylinders on my 66 val are going to set me back $25 each unless I can rebuild 'em. $50 is too much to spend until I know if I am keeping this thing. I got too much $ in it already!!!!
So I got one front bleeder out using the torch and wax method. The second one broke off. What to do now?? I have never had much luck drilling them out. Seems like the tips are hardened and I can't drill all the way through them.
Do any of you you have a magic trick for this??
Thank you!!!
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri Oct 26, 2007 10:37 am
Well I destroyed it.................. :x
But if anyone has a good trick I'd still like to hear about it.
PostPosted: Fri Oct 26, 2007 10:49 am
In a pinch you can bleed the wheel cylinder by breaking loose the line at the wheel cylinder as someone pushes the brake pedal.
Franklin
'61 Valiant
 Post subject: bleeding
PostPosted: Fri Nov 02, 2007 6:16 am
Also use the feeler gauge method from my high school shop teacher.
With the drum removed pull the dust boot back and slide a thin feelers gauge at the top of the cylinder, past the cup to bleed the air out. this takes two people so have a helper. Crude method but can save ya a few bucks and some down time.
PostPosted: Fri Nov 02, 2007 10:28 am
Yes. Get the new wheel cylinders and save the frustration.
