It is currently Mon Dec 02, 2024 10:38 am
PostPosted: Tue Nov 06, 2007 5:16 am
I know years ago, direct connection recommended a windage tray as part of their slant six builds, but I'm just wondering now that they're not so easy to come by if they are really of much benefit in a street car. All the old magazines used to say they were cheap horse power, because they kept they oil off the crank. Wouldn't that apply more to higher RPM operation? Any thoughts? - Blair
Blair Furlotte
1979 Dodge Aspen 225 "Super Six" 3-speed
Original owner
PostPosted: Tue Nov 06, 2007 5:53 am
Mike Jeffrey makes a copy of the old DC tray, and also makes scrapers. 308-324-3576. He does them during the winter when he is not farming or racing. :shock:
PostPosted: Tue Nov 06, 2007 7:22 am
Windage trays and crank scrapers do make a difference at high rpms, where the racers are looking for any extra power they can get, and where street cars seldom go.
Are they worth the purchase price and cost of installation? It's a little like asking about the best color for your car. It all depends ...
I sure wouldn't tear an engine down just to install them. But if I were building an engine to occasionally race (after I win the lottery) and wanted to make sure I covered all the bases, I'd do all sorts of oil-control work including scrapers and maybe a tray.
It'd be interesting to see a good test with and without, comparing fuel use at the same acceleration rates to and from city/highway speeds.
PostPosted: Tue Nov 06, 2007 1:01 pm
There was a big thread on scrapers/trays a year or two ago on here. The only one claiming good power gains out of a scraper/tray on the street was someone else selling them. Mike claims about 7 horse at upper RPM for a tray, he never said on a scraper. :shock:
Personally, for just a street motor a scraper would be of more value than a tray. Plus, the trays have been known to crack at the "legs" and get into the crank. :(
PostPosted: Fri Nov 09, 2007 6:22 pm
What is a crankshaft scraper? I know what a windage tray is.
PostPosted: Fri Nov 09, 2007 6:34 pm
6 Pack Dart
strips of metal attached to the block and cut so the crank shaft will clear them when the rod ends and weights go around, it prevents the air from creating a hurricane force wind from picking up oil in a mist like condition.
PostPosted: Sat Nov 10, 2007 3:57 am
As I understand it, Oil clings to the rotating assembly and at high RPMs tends to wrap around it, increasing drag and possibly starving the engine of oil. A crank scraper peels the oil away from the crank and returns it to the sump while a windage tray helps keep the oil in the sump where it can be circulated through the oiling system.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Nov 10, 2007 8:45 am
Crank scrapers are a nice addition and a 'must do' for any high RPM engine.
On the down side, getting a good scraper fitted into the engine is time consuming, there is a lot of trim, test-fit & trim again work.
The real bummer is when you spend hours getting everything to clear and you bolt down the oil pan, give the engine a test spin and "tink"... something in there is still hitting. :x :cry:
Here is a shot of a scaper installed on a SL6
Click Here for a close-up photo.
PostPosted: Sat Nov 10, 2007 10:44 am
I highly recommend the Ishihara-Johnson crank scrapers. I have bought two, and they both fit with minimal trimming with an angle grinder. Well worth the $50 (one side) or $75 (both sides) for these nice pieces. They usually have a set on ebay.
I see no problem with replacing the rail gaskets with scraper parts since permatex will easily seal leaks. I have about 6k street miles on my 64 Dart since installation. I had no oil pressure loss on the road course with my 3/4" dropped and baffled pan, and the one-sided scraper.
PostPosted: Sun Nov 11, 2007 6:31 am
Doc is that all you will be putting on this engine- just one side? I see you have provisions for a tray.
Also, do the cast crank engines require different pieces altogether?
Blair Furlotte
Original owner
PostPosted: Sun Nov 11, 2007 8:11 am
Cast crank engine use the same parts but the 'fitting' will be a little different seeing that the con rods are thinner.
The engine shown uses a scraper and a windage tray.
I only use one scraper, the one on the cam side. This is to stop windage from coming up from the pan area and going around to the block side of the crank. (based on the direction of crankshaft rotation)
I see little value in placing a scraper on the other side.
PostPosted: Sun Nov 11, 2007 11:39 am
OK Doc
Why are the Rods so shiny??? Mine dont look smooth or shiny.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Nov 11, 2007 8:47 pm
OK Doc
Frank
Those con rods are lightened and polished.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 17 guests
