| No Brakes! https://slantsix.org/forum/viewtopic.php?t=25712 |
| Author: | sharp21 [ Tue Nov 06, 2007 10:20 am ] |
| Post subject: | No Brakes! |
Ive been away at work for the last few months. Got home, jumped in the Volare & she fired right up! Running great. Went to go for a lil spin & I noticed that the brake pedal now goes alllll the way down! I can get just a lil bit of braking action. Havent popped the hood yet. Ill take a look this afternoon. S. |
| Author: | sharp21 [ Tue Nov 06, 2007 2:46 pm ] |
Well the resevoir is pretty much empty. Im gonna top it up then try to find the leak... S. |
| Author: | Pierre [ Tue Nov 06, 2007 4:05 pm ] |
May have to take the drums off if nothing is obvious. |
| Author: | sharp21 [ Tue Nov 06, 2007 9:39 pm ] |
I got it filled & its a lil better, but I cant see any leak when i pump the brakes... Have to pull a tire off when I get a chance S. |
| Author: | Pierre [ Tue Nov 06, 2007 11:08 pm ] |
Which reservoir was low? IIRC the larger rearmost one feeds the front brakes. |
| Author: | sharp21 [ Wed Nov 07, 2007 8:30 am ] |
They both were, but the rear one took a few times to top up. I definately got some feel back, but they need to be bled down. S. |
| Author: | dank10fenny [ Tue Nov 13, 2007 5:22 pm ] |
empty? or pretty much empty? if u sucked up air, i would bleed the brakes, remeber that fliud will go down as pads and shoes wear... may not even be a leak... |
