| Starter Choices https://slantsix.org/forum/viewtopic.php?t=2576 |
| Author: | Winklovic [ Sun Aug 19, 2001 8:53 am ] |
| Post subject: | Starter Choices |
The starter on my '80 Volare Sl6 is dying a slow death. I know the mini starters from Rams and Dakotas will work but are there any others I can try, like from the Chrysler powered mini-vans? I'm planning on visiting the boneyard soon so any advice would be appreciated. Also, since this will be the first time I've installed a starter, is there anything I should know about how to do it properly? I have the FSM handy. bmazur3@home.com |
| Author: | SL6 Daniel [ Sun Aug 19, 2001 10:41 am ] |
| Post subject: | Re: Starter Choices |
: The starter on my '80 Volare Sl6 is dying a : slow death. I know the mini starters from : Rams and Dakotas will work but are there any : others I can try, like from the Chrysler : powered mini-vans? No, front-wheel-drive starters do NOT fit rear-wheel-drive cars. If you want to play with the late-model mini Japanese starter, it's off any '89 or later RWD Chrysler-product V6 or V8. Jeep 6s and V8s are NOT included in the interchange. : : Also, since this will be the first time I've : installed a starter, is there anything I : should know about how to do it properly? Remove negative battery cable from battery Remove small and large cable connections from starter (do NOT lose washers and nuts) 5/8" wrenches to remove upper and lower starter fixing hardware Remove starter, do NOT lose starter-to-bellhousing shim plate Installation is the reverse of removal. DS redbear@vrx.net |
| Author: | Winklovic [ Mon Aug 20, 2001 8:42 am ] |
I made a view calls this morning and I can get a used mini-starter for $90 Cdn or a Wilson starter for $87. Is anyone familiar with the Wilson name? bmazur3@home.com |
