Slant Six Forum https://slantsix.org/forum/ |
Dip stick https://slantsix.org/forum/viewtopic.php?t=25763 |
Author: | rickychicken [ Fri Nov 09, 2007 1:13 am ] |
Post subject: | Dip stick |
All of my years with I have never snapped off a dip stick housing. What is the best fix for this?. I know someone has had this happen to them, I can't be the first one. Even the cat shook his head and walked away. |
Author: | dakight [ Fri Nov 09, 2007 3:09 am ] |
Post subject: | |
I don't know of any fix other than to replace the tube. A tube should not be hard to find. |
Author: | 1969ronnie [ Fri Nov 09, 2007 4:55 am ] |
Post subject: | |
hi, i think he is looking for tricks and tips to get the small piece of tube left in the block out. ron |
Author: | rickychicken [ Fri Nov 09, 2007 6:08 am ] |
Thank you for the answer. I have had at leat three dozen motors here and I have never snapped one off before, first time in 25 years. |
Author: | gato [ Fri Nov 09, 2007 8:00 am ] |
Post subject: | |
my dipstick tube slides in and out easily. has been that way for years. maybe u can pull the stub out with an Easy-out, or some sort of screw extractor? D~~~! |
Author: | rickychicken [ Fri Nov 09, 2007 10:32 am ] |
Thanks for the info. Been too long to remember what we would do before. I know there is a universal kit made that will bolt onto the oil pan but. don't know that will look. I think we would take the stub out and thread the block and use a piece of 1/8 pipe or something like that. I called Mitchell's and Frank said that from time to time he gets them in. I have the part number. What is the last year they made the slant 6, don't remember, I am sure everyone know but me, thanks. Jim |
Author: | rickychicken [ Fri Nov 09, 2007 3:09 pm ] |
Post subject: | dip stick |
Getting slow in my old age but, I am catching up with the past. I was thinking about the dip stick. I went to NAPA and got a piece of 3/8 steel gas line, cut it and it was tight enough that I had to drive it in with a hammer. Cut it to length and then took the bender and put a small off-set to match the original one and it works just fine, new and tight. The stock tube is made of the same thing. |
Author: | 1969ronnie [ Sun Nov 11, 2007 8:43 am ] |
Post subject: | |
Author: | Doctor Dodge [ Sun Nov 11, 2007 9:06 am ] |
Post subject: | |
Quote: ...I went to NAPA and got a piece of 3/8 steel gas line, cut it and it was tight enough that I had to drive it in with a hammer. Cut it to length and then took the bender and put a small off-set to match the original one and it works just fine...
True SL6 'make it work-manship' at it's finest. Well Done! ( "we don't need no stinken' over priced NOS dipstick tube) ![]() ![]() |
Author: | rickychicken [ Sun Nov 11, 2007 1:17 pm ] |
Post subject: | Dipstick |
The steel tubing is exactly the same gage and size all around. In fact when you drive it in with a piece of wood you can see it shave off about one thousand, tight enough you can take the tubing cutters and cut it off to length and then take a tubing bender and put the little bend in to clear the manifold. It made me so good that I think I will open the hood of all the rest of the cars and brake them all off, ha! |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
