It is currently Fri May 15, 2026 6:10 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: studs for heads
PostPosted: Tue Sep 04, 2001 2:31 pm
I would like to run studs instead of headbolts to fasten the head to the block. Does anyone make a stud kit for slant6?
ral4651@greenapple.com
 Post subject: Re: studs for heads
PostPosted: Tue Sep 04, 2001 9:39 pm
: I would like to run studs instead of headbolts
: to fasten the head to the block. Does anyone
: make a stud kit for slant6?
I got a set from A.R.P products but I'll bet that the Cox Brothers can dig you up a set.Their phone number is 614 268 9920 or try J & M 308 324 3576 last place is Clifford 909 734 3310
damuel@kalama.com
PostPosted: Tue Sep 04, 2001 10:57 pm
: I got a set from A.R.P products but I'll bet
: that the Cox Brothers can dig you up a
: set.Their phone number is 614 268 9920 or
: try J & M 308 324 3576 last place is
: Clifford 909 734 3310
ARP is the "sure bet" seeing that we spent a bunch of time "cross-checking" eveything with them a number of years back.
Go to the link below to get all the nitty-gritty details or just grab the ARP part numbers off this photo:
ARP Studs & Bolt Info.
