removing engine question
https://slantsix.org/forum/viewtopic.php?t=25823
Author:  GeoEray [ Mon Nov 12, 2007 4:55 pm ]
Post subject:  removing engine question
What are the best points to attach a chain to remove the slant six?
Author:  1974duster kev [ Mon Nov 12, 2007 5:18 pm ]
i used one of those 10,000lb nylon straps and fished it againts the block inbetween the exhaust/intakes toward middle of engine down side under back up between oil pump area (theres like a little spot to fish it between the oil pump maybe right side? centers it well and the strap or chain won't slide side ways once your lifting adjust accordingly pulling strap lower or higher to one side till it levels.didn't give me much problem popping it out like that
Kevin
Author:  dakight [ Mon Nov 12, 2007 5:51 pm ]
there are a couple of drilled and tapped bosses on the upper surface of the head, between the manifolds and valve cover. They were put there for that purpose.
Author:  GeoEray [ Mon Nov 12, 2007 6:44 pm ]
Thanks for the info!
George
Author:  Doctor Dodge [ Mon Nov 12, 2007 7:27 pm ]
