| Double check--manifold clearance https://slantsix.org/forum/viewtopic.php?t=2583 |
| Author: | Alex [ Tue Aug 21, 2001 2:16 pm ] |
| Post subject: | Double check--manifold clearance |
Just to double check....I'm upgrading my '65 170 to a 2bbrl intake. I am also going to get another exhaust manifold. Are there any clearance problems between the the combinations of 225/170 exhaust manifolds and the 2bbrl intake? What about steering clearance and such? Orionsax7@cs.com |
| Author: | Doc [ Tue Aug 21, 2001 3:34 pm ] |
| Post subject: | Re: Double check--manifold clearance |
: Just to double check....I'm upgrading my '65 : 170 to a 2bbrl intake. I am also going to : get another exhaust manifold. Are there any : clearance problems between the the : combinations of 225/170 exhaust manifolds : and the 2bbrl intake? What about steering : clearance and such? Everything should bolt right-up. The only thing you may have to "rework" is the length of the kick-down rod (if it's an auto trans) The shorter 170 will make the rod seem to long. DD |
