| gas tank sender removal? https://slantsix.org/forum/viewtopic.php?t=25867 |
| Author: | dank10fenny [ Thu Nov 15, 2007 12:21 pm ] |
| Post subject: | gas tank sender removal? |
just seeing if theres a trick to openin up the gas tank through the sender, i got it pulled. im tryin to clean it out from sittint about a decade. it looks like its half spanner style. but i dont wanna go wailin on any taps tryin to get it to spin... |
| Author: | SlantSixDan [ Thu Nov 15, 2007 12:28 pm ] |
If you don't have the correct spanner, use a non-sparking (brass, bronze, copper, plastic, wood) drift, and not a steel one, to turn the locking ring counterclockwise. |
| Author: | dank10fenny [ Thu Nov 15, 2007 12:36 pm ] |
k, just makin sure it actually is a spanner. got a lil grime on it. ill give it a try wit a BFH... jk... theres not gas in it right now, not even fumes... |
| Author: | KBB_of_TMC [ Fri Nov 16, 2007 4:03 pm ] |
I couldn't find the correct spanner, so I took the aluminum U-shaped heating element from a dead coffee maker and filed notches in it to make a crude spanner - it got the job done, but I'll find something better next time. |
