It is currently Sun Nov 15, 2026 12:41 pm
 Post subject: gas tank sender removal?
PostPosted: Thu Nov 15, 2007 12:21 pm
just seeing if theres a trick to openin up the gas tank through the sender, i got it pulled. im tryin to clean it out from sittint about a decade.
it looks like its half spanner style. but i dont wanna go wailin on any taps tryin to get it to spin...
PostPosted: Thu Nov 15, 2007 12:28 pm
If you don't have the correct spanner, use a non-sparking (brass, bronze, copper, plastic, wood) drift, and not a steel one, to turn the locking ring counterclockwise.
PostPosted: Thu Nov 15, 2007 12:36 pm
k, just makin sure it actually is a spanner. got a lil grime on it. ill give it a try wit a BFH... jk... theres not gas in it right now, not even fumes...
PostPosted: Fri Nov 16, 2007 4:03 pm
I couldn't find the correct spanner, so I took the aluminum U-shaped heating element from a dead coffee maker and filed notches in it to make a crude spanner - it got the job done, but I'll find something better next time.
