| ammeter spiked for a 3 seconds https://slantsix.org/forum/viewtopic.php?t=25910 |
| Author: | makapipi [ Mon Nov 19, 2007 12:05 am ] |
| Post subject: | ammeter spiked for a 3 seconds |
driving home other night , noticed ammeter went up above normal about halfway, lites went bright then went out, changed head lites, next day hooked up voltmeter went driving and found voltage went up 18, 19 volts for 1 or 2 seconds. changed alternator, while holding bad alt, 2 pieces of aluminum foil fell out, maybe that caused the intermittent hi volt problem. too scared to put back original alt. so far new alt has good voltages. i was lucky no more damage occurred. before i used to change alt every 5 years regardless if still working, to prevent weird problems. |
| Author: | phogroian [ Wed Nov 21, 2007 7:29 am ] |
How about your voltage regulator? Is there any corrosion on the mounting area that would prevent a good ground? do you have a spare regulator that you can swap out to see if it is bad? |
