Trans "?"
https://slantsix.org/forum/viewtopic.php?t=2593
Page 1 of 1
Author:  MrMopar [ Thu Aug 23, 2001 5:47 pm ]
Post subject:  Trans "?"
Hi Guys
What is the difference in a 904 and a A-904
and how do you tell
Which one if any would come in a 64 Fury with a slant six
Thanks
Randy
mopar.mopar@gte.net
Author:  mark dingbaum [ Tue Aug 28, 2001 7:53 am ]
Post subject:  904 differences
Hi,
I don't think there is much difference in any Aluminum 904 except some obvious things.
Cable shifted or linkage shifted (pre or post 65/66)
Bolt on driveshaft flange or slip yoke (pre or post '64/65)
Bellhousing pattern is different for slant six vs small block vs big block.
I don't think there are any slant six pattern 727s, but I believe the factory used sb pattern 727s behind slant sixes with an adapter.
Some of the very late 904s use a lockup converter and different gearing 2.74/1.54 vs 2.45/1.45.
The reaction support shaft (going into converter) is was changed in the late 60s (66/67?).
I would guess a '64 car would have a cable shifted 904 with a flange driveshaft attachment, early reaction support, 2.45/1.45/1.0 gearing.
This is all from memory/hearsay and might easily be incorrect. Feel free to email me if you want more info.
good luck,
mark
mldingba@collins.rockwell.com
Author:  GTS225 [ Tue Aug 28, 2001 10:28 am ]
Post subject:  Re: 904 differences
: I don't think there are any slant six pattern
: 727s, but I believe the factory used sb
: pattern 727s behind slant sixes with an
: adapter.
Mark, on this point I believe you're incorrect. There was a taxi/police package in the early/mid 70's, possibly into the 80's, that had a direct-bolt 727 in the /6 pattern. The 727 was also used somewhat heavily in trucks behind the /6.
Roger
GTS225@aol.com
Author:  Dart270 [ Tue Sep 04, 2001 11:20 pm ]
: Mark, on this point I believe you're incorrect.
: There was a taxi/police package in the
: early/mid 70's, possibly into the 80's, that
: had a direct-bolt 727 in the /6 pattern. The
: 727 was also used somewhat heavily in trucks
: behind the /6.
: Roger
Mark,
You are correct about the SB 727 and adapter plate. They were used especially on early pickups/vans, but are fairly rare. I think the /6 727 came out around 1969 or 70.
madsenl@caltech.edu
