Differences in '65 and '69 4-speed linkage?
https://slantsix.org/forum/viewtopic.php?t=25975
Author:  b5cuda [ Fri Nov 23, 2007 11:02 am ]
Post subject:  Differences in '65 and '69 4-speed linkage?
I've got a pedal assembly and z-bar from a '65 Dart, wondering if they will both fit in my '69 cuda? Both are for small-block. The z-bar to frame rail ball stud looks different, has a plate mounted to it rather than just a screw-in ball stud. Thanks,
Bill
69 fb
Hillsboro, OR
Author:  65 dartman [ Fri Nov 23, 2007 2:20 pm ]
Post subject:  Re: Differences in '65 and '69 4-speed linkage?
The 65 stuff will fit only the early A Body. You need the stuff from the 67-69 A body. Possibly the 70-76 stuff might work as well but am not sure about that.
Author:  DusterIdiot [ Fri Nov 23, 2007 4:51 pm ]
Post subject:  That will work...
Yep...I just put a 1974 A-230 in my '67, I used a 1976 Z-bar, a set of pedals from a '73, and the linkage was from a '74 (with new bushings, etc from Brewers). Everything bolted up just like it was meant for that car...
Author:  b5cuda [ Fri Nov 23, 2007 9:37 pm ]
Thanks guys - much obliged for the help! Will let you know how it works out.
