It is currently Fri Feb 21, 2025 9:38 pm
 Post subject: fast idle cam
PostPosted: Fri Nov 23, 2007 4:06 pm
Posted earlier about my missing fast idle cam that I found on a second carburetor. Got to thinking: Why shouldn't both my carburetors have fast idle cams? They are Carters. Any suggestions on where to find another cam and shaft?
PostPosted: Fri Nov 23, 2007 4:33 pm
Yes, they should both have fast idle cams...sounds like one fell off somewhere along the line. They're not to be had new; you'll have to rob one off another carb (but if you're only using one carb at a time, you only need one fast-idle cam at a time...)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 76 guests
