It is currently Fri May 15, 2026 11:25 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: GM T-5 behind slant six
PostPosted: Sat Aug 25, 2001 8:56 pm
info from Carol Hadfield
Tim,
The V6 T5 we use here in
Australia for the Hemi and Slant 6 has a 9 1/2" input shaft length. The cost
in
Australian dollars is $250.00, it bolts to the chrysler bellhousing, has
a
spigot bush with it and we machine out the thrust carrier to fit the GM
slide.
Regards, Rod
tkeith@mindspring.com
