| Same break backing plate bolt pattern 7.25 & 8.75? https://slantsix.org/forum/viewtopic.php?t=2601 |
| Author: | Walt Jackson [ Sun Aug 26, 2001 8:48 pm ] |
| Post subject: | Same break backing plate bolt pattern 7.25 & 8.75? |
Master Power Brakes offers a rear disk brake package for the 8.75 rear end. It bolts on in place of the drum brake backing plate. Is the bolt pattern the same as the 7.25 rear end? That's what I'd like to bolt the package to. --Walt Jackson WalterLeeJackson@compuserve.com |
| Author: | dschumers [ Mon Aug 27, 2001 6:14 pm ] |
| Post subject: | Re: Same break backing plate bolt pattern 7.25 & 8 |
: Master Power Brakes offers a rear disk brake : package for the 8.75 rear end. It bolts on : in place of the drum brake backing plate. : : Is the bolt pattern the same as the 7.25 rear : end? That's what I'd like to bolt the : package to. : : --Walt Jackson If your 7.25 has 10" brakes with the 4-1/2" bolt pattern, you are in business. It should also have 5 studs holding the backing plate on. Mine with 9" brakes and small 4" pattern only have 4. aschumers@aol.com |
