It is currently Mon Jun 22, 2026 8:47 am
 Post subject: Timing - again
PostPosted: Thu Dec 06, 2007 1:46 pm
Hi guys - need some advice
I set my timing for total mech of 32 deg @ 2600 following the mopar engines book - I see some of the guys run 32 a@2000 - advice will be appreciated
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
 Post subject: timing
PostPosted: Thu Dec 06, 2007 3:46 pm
when i ran my 10/1comp engine it liked 32deg to be all in at 2500. it`s just the way my setup ran best , 528lift/ 284deg/int&ex 3.90 8 1/4 600cfm vac secondary/3000 stall conv. also no vac advance.
PostPosted: Thu Dec 06, 2007 6:35 pm
My engine likes more timing. It runs best at 32 degrees at 2500.
