Hood Hinge lube
https://slantsix.org/forum/viewtopic.php?t=26041
Author:  66aCUDA [ Thu Nov 29, 2007 11:12 am ]
Post subject:  Hood Hinge lube
Whats the best way to lube the hood hinges? Im having trouble getting the hood up and down without bending it.
Thanks
Frank
Author:  SlantSixDan [ Thu Nov 29, 2007 11:56 am ]
You ought to be able to break loose the frozen rollers at the ends of the hood torsion bars by using a good penetrating oil such as Kroil or P'Blaster (forget WD40 or Liquid Wrench). Then apply a couple of drops of regular engine oil to the rollers where the bars go through 'em, and to the actual swing hinges.
Author:  66aCUDA [ Thu Nov 29, 2007 1:12 pm ]
Ill use PB.
Thanks Dan as usual you are a wealth of info.
Frank
Author:  Davids63Dart [ Thu Nov 29, 2007 7:00 pm ]
After you get it broken loose, I use grease to keep it protected. I pack it with grease and wipe the excess off to make it look cleaner and protect it from sticking again later.
Author:  Romeo Furio [ Fri Nov 30, 2007 8:03 am ]
Post subject:  grease
Try BOAT wheel bearing grease that is water proof.
Author:  66aCUDA [ Fri Nov 30, 2007 8:06 am ]
Thanks Dave and Romeo
Those are great tips.
Frank
