/6 redline and cruising rpm
https://slantsix.org/forum/viewtopic.php?t=26050
Page 1 of 1
Author:  pinkiedog64 [ Fri Nov 30, 2007 12:41 pm ]
Post subject:  /6 redline and cruising rpm
I have a '64 D100 with a 3 on the tree 225 /6. The head has been milled .100", ported & polished, new guides, hardened seats, and the engine has the Super six carb, intake and exhaust. What is the recommended redline rpm for this engine? Also, what's a safe cruising rpm for highway driving (long trips)?
Thanks
Author:  Aggressive Ted [ Fri Nov 30, 2007 1:33 pm ]
Redline and where it gives up are about the same, about 4000 with a one barrel.
Nice place for cruise is about 2500 to 2700 rpm, right in the middle of the torque band.
Author:  DusterIdiot [ Fri Nov 30, 2007 5:11 pm ]
Post subject:  Depends on gearing and tire size, etc...
Cruise rpm will depend on carb size, tire size, rear ratio...
2500-2700 for a 1 barrel
can get as low as 2300 with more carb, gearing, etc...
Redline on a 'worked over engine' is about 5-6K... stock bottom end with old bearings should be about 3500-4000 (don't say I warned ya...)
Author:  walpolla [ Fri Nov 30, 2007 7:55 pm ]
redline?
this is redline
unfortunately the poor ole slant has a bad habit of poking # 5 out. :x
without a good build,if you are looking for max revs,that will probably happen.
seen several over the years. keep it under 4k and (hopefully) you should be sweet.
regards,Rod :D :D
Author:  Dart270 [ Sun Dec 02, 2007 5:15 am ]
4000 rpm is about where the power starts to really drop off. I have cruised a well rebuilt stock-internals engine at 36-3800 all the way across the country with no ill effects.
I would say 5000 is totally safe for stock internals if the engine isn't gummed up inside. I was running my V motor (junkyard shortblock) to 5500 road racing and that was 100% fine. BUT, when I went to 6000 redline it gave up.
My '64 Dart motor has a well rebuilt stock-type bottom end with cast pistons and balanced assy and looser bearing clearances and it is good to 6000.
