It is currently Fri Jun 19, 2026 5:47 am
 Post subject: Crank Pulley's
PostPosted: Fri Nov 30, 2007 12:19 pm
I started the installation of my AC and was missing a dual crank pulley
Hmm went down to the local Performance shop and had a browse around
AND
extra pulleys for gm application - billet ally! - fits same bolt spacing as slant
:D
will see if the billet waterpump pulley also fits......... :D
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
 Post subject: pulley
PostPosted: Fri Nov 30, 2007 6:41 pm
the 3 (3/8in) tapped hole in a stock damper are the same pattern as the sb chevy, i found that helpful when making my serpentine belt drive.
 Post subject: Re: pulley
PostPosted: Sat Dec 01, 2007 5:50 am
Very interesting - this gives me some new thoughts on my crank trigger setup!
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Dec 01, 2007 7:21 am
Yup the 3/8s line up nicley
But after dip in deoxidine - a local derusting/phosphating agent, of the balancer wich I found in my NOS stockpile - the keyway showed a hairline crack :cry:
Regards,
Fanie Gerber
PostPosted: Sat Dec 01, 2007 7:26 am
Doesn't sound like the damper was NOS after all.
PostPosted: Sat Dec 01, 2007 12:26 pm
Nope :cry: - I know it was used , the rest of the stuff is quite NOS still in their blue and white Genuine Chrysler Parts boxes :D
Regards,
Fanie Gerber
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
