Block ID numbers
https://slantsix.org/forum/viewtopic.php?t=2606
Page 1 of 1
Author:  WhaleMstr [ Mon Aug 27, 2001 10:50 am ]
Post subject:  Block ID numbers
Howdy all,
Just got my "new" '69 A108 home the other day and I would like to find out what motor it is.
Here are the numbers on the side of the block - 2808803-1
I can't remember where on the net the site was that told you how to decifer this. The one problem with the net - way too much stuff!!
For some reason I think it's a 170 built in '68?
Thanks for any help,
Dan
"I may be slow, but at least I'm not very fast!"
gramma@dm-tech.net
Author:  Doctor Dodge (Doug Dutra) [ Mon Aug 27, 2001 9:47 pm ]
Post subject:  Re: Block ID numbers
: Howdy all,
: Just got my "new" '69 A108 home the
: other day and I would like to find out what
: motor it is.
: Here are the numbers on the side of the block -
: 2808803-1
Ummmm....I can't find that casting number, are you sure? is the number clear and easy to read?
Does the block have 3 or 5 freeze plugs in the side?
My 66 170 with 3 freeze plugs is casting number 2463230
If you use the search function and type-in '170 blocks numbers' and serch for "all" lot's will come-up.
Author:  WhaleMstr [ Tue Aug 28, 2001 8:20 am ]
Hey Doc,
I went out and was able to clean the ID plate on the wheel well and found out it is a 225 with an A745 tranny.
Thanks for the help,
Talk at ya later,
Dan
gramma@dm-tech.net
