Grease is grease-right ?? or ...
https://slantsix.org/forum/viewtopic.php?t=26064
Page 1 of 1
Author:  slanty6 [ Sat Dec 01, 2007 6:43 pm ]
Post subject:  Grease is grease-right ?? or ...
I am wrapping under the undercarriage rebuild of the 74 Satellite quickly. I have packed the front wheel bearings w/ a hi temp red grease formulated for roller bearings I got from work (I'm a maintenance mechanic). I have yet to grease the ball joints, tie rod ends and the pitman and idler arms. Since the new rubber seals on these are just marginal, I was considering some type of heavy equipment or fifth wheel grease so washout would not be such a problem. Rich Ehrenburg recommends Chryslers "barium based long fiber grease". I can obtain it but I have to buy a full case (10 tubes) for $80. Am I being way too critical here ?? What does everyone on here use on their own front ends ?? Thanks in advance..
Author:  emsvitil [ Sat Dec 01, 2007 6:51 pm ]
I've used the moly (black stuff) for years in everything I have....
I think it's more important to actually lube things, than what's going in (except don't get cheap stuff)..............
Author:  66aCUDA [ Sun Dec 02, 2007 7:58 am ]
If you go with the $80 case. You may want to list tubes on the For Sale section, You may even be able to presell it?
Just a thought.
Frank
