Super Six kickdown linkage
https://slantsix.org/forum/viewtopic.php?t=26067
Page 1 of 1
Author:  NewSlanter [ Sun Dec 02, 2007 9:33 am ]
Post subject:  Super Six kickdown linkage
Is it more important to have the kickdown adjusted so it's fully forward when the throttle blades are closed or fully to the rear when the carb is at WOT? I ask because there doesn't seem to be enough travel at the stud on the carb to have it both ways. I have it adjusted fully to the front and the car seems to be performing well, but I'd like to know the "right way" so I know I'm not doing any damage.
Nat
Author:  SlantSixDan [ Sun Dec 02, 2007 10:17 am ]
The correct adjustment has the trans lever all the way forward when the throttle is at the correctly-adjusted curb idle position. You can move it slightly from there to adjust it to your personal preferences.
Author:  NewSlanter [ Sun Dec 02, 2007 10:23 am ]
Thank you sir!
