It is currently Tue Jun 16, 2026 1:36 pm
PostPosted: Mon Dec 03, 2007 2:30 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Hey All,
I've got a '71 slant that's propane-powered, so I want to get the compression ratio up to 10.5:1. The head can be shaved to .1", correct? I'm running an Erson RV-type cam along with it.
Any suggestions appreciated,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
 Post subject: Er, yes but...
PostPosted: Mon Dec 03, 2007 6:43 pm
Yep you can take that off a head (and more sometimes)... just make sure to check how far down the pistons are in the bore, and figure out which head gasket you are using, then run the numbers through a compression calculator to see what your combustion chamber size needs to be...before you cut..you may not need to take the whole .1 off...or you may need to take more off...
PostPosted: Tue Dec 04, 2007 11:03 am
Thanks, D'idiot. I'll let you know how it turns out.
Joe
Joe Hoppe
