It is currently Mon May 18, 2026 10:31 am
 Post subject: head gasket
PostPosted: Wed Oct 17, 2001 3:46 pm
Just wanted to let you know that the head gasket went on fine and my car also does not miss anymore. the car feels stronger then ever and thats only at 3 psi. Hopefully I will be able to get to the track before they close up. I will let you know!!!!
andrew wagner
 Post subject: Re: head gasket
PostPosted: Wed Oct 17, 2001 6:26 pm
: Just wanted to let you know that the head
: gasket went on fine and my car also does not
: miss anymore. the car feels stronger then
: ever and thats only at 3 psi. Hopefully I
: will be able to get to the track before they
: close up. I will let you know!!!!
: andrew wagner
Andrew,
Let us know if you head down to Mason-Dixon Dragway, I'm not far away and would like to come down and see you run.Keep up the good work.
Rick Covalt
rcovalt@innernet.net
