It is currently Wed Dec 31, 2025 11:51 pm
 Post subject: BBD problems
PostPosted: Sun Dec 09, 2007 10:23 pm
i got a recently rebuilt carter that's confusing me. The car won't idle unless the EGR venturi tap is uncapped. Also when ya remove the vacuum advance it stalls out and dies. I thought it should still run without the advance? Any ideas whats going on with it guys?
'66 Barracuda super six turbo??
PostPosted: Sun Dec 09, 2007 10:51 pm
it sucks air at idle on a venturi vac port? where can air be bypassed? and enough to kill it. you have checked timming eh?
PostPosted: Sun Dec 09, 2007 11:19 pm
don;t know if it's sucking air at idle from the venturi port. Only that it won't idle down at all with it capped. timing should be at 2BTDC from where i set the dist less than a week ago.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
