It is currently Wed Dec 31, 2025 7:19 am
PostPosted: Mon Dec 10, 2007 9:14 pm
Git a load of the exhaust manifold on the engine that comes with this '69 Charger.
Here's a pic cadged from the auction; click for (much) bigger:
PostPosted: Mon Dec 10, 2007 9:32 pm
Looks like the "power pipe" has compitition........
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
PostPosted: Mon Dec 10, 2007 10:01 pm
Now that is an interesting project for the right person. I haven't seen many B-body engine bays with a slant, but I am guessing that it is down right cavernous. There is a lot of room for a better manifold, and a really big turbo in there.
PostPosted: Mon Dec 10, 2007 10:37 pm
Interesting. The collector is a little wonky, but the fab work doesn't look bad at all. Too bad he chose such a small turbo. Looks like it's from a Turbo II.
PostPosted: Tue Dec 11, 2007 2:27 am
I'm wondering if internally the collector has some flow control so it's not as bad as it seems. (the boxy collector is to make sure there's not any leaks)
PostPosted: Tue Dec 11, 2007 4:42 am
that thing looks like its almost welded right to the head isn't it? that flange must be like a quarter inch thick.
ack!
:shock:
PostPosted: Tue Dec 11, 2007 6:41 am
He who made it states: " I was bored one day and started tinkering. Not real pretty, but for my first attempt, I thought it was good. The center box has a shaped divider in the middle, so the exhaust pulse from #1 doesn't push back on the pulse from #6."
PostPosted: Tue Dec 11, 2007 7:54 pm
:shock:
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
