head games
https://slantsix.org/forum/viewtopic.php?t=26184
Page 1 of 1
Author:  mopardean [ Sun Dec 09, 2007 5:42 pm ]
Post subject:  head games
Will the head from a hydralic lifter slant 6 work on a mechanical lifter engine? are there any modifications required?
thanks
dean
Author:  Doctor Dodge [ Sun Dec 09, 2007 7:38 pm ]
Everything will swap over.
You will have to use the later valve cover and use the rocker arms and push rods form the early engine. (machanical lifter set-up)
Author:  mopardean [ Tue Dec 11, 2007 8:33 pm ]
ok thanks
a guy i know at a machine shop has a redone head for a hydralic motor including guides and seals and complete valve job for 125$. dol you think this is a good deal
thanks dean
Author:  SlantSixDan [ Tue Dec 11, 2007 9:15 pm ]
Yep, good price. You will, as Doc says, need an '81 or later valve cover, and you'll need up-to-'80 solid-lifter rocker shaft and arms and pushrods.
Author:  mopardean [ Tue Dec 11, 2007 9:26 pm ]
thanks again Dan
Dean
Author:  mopardean [ Thu Dec 13, 2007 6:56 am ]
i just found out that the work on this head was done 10 or so years ago and it has been setting in this guys shop all that time. it is dirty and dusty. do you suppose it would still be good? i can clean it up i think but would the seals and such still be ok?
thanks dean
Author:  66aCUDA [ Thu Dec 13, 2007 7:15 am ]
Dean
I would still think you would come out ok (price wise) at worst case you might have to replaced the seals, but they will probally be ok.
Frank
Author:  mopardean [ Thu Dec 13, 2007 11:18 am ]
Thanks Frank
i think i am going to go ahead and get this. as long as i keep my old slants i am sure to find a use for it sometime. My 87 1/2 ton is using oil and i have a few things to try per Dan's and others recommendations on this board but eventually it will need a new head.
Dean
